Connect bridge-to-bridge
Does anyone know of a way to connect bridges together with an attenuated RF cable? I have quite a WLAN network that I would like to have talking on the ground before I move the devices to their towers. It involves 19 AR-350's.
Thanks in advance!
Re: Connect bridge-to-bridge
Since there has been no response to your post, it appears to be either too complex or too rare an issue for other forum members to assist you. If you don't get a suitable response to your post, you may wish to review our resources at the online Technical Assistance Center (http://www.cisco.com/tac) or speak with a TAC engineer. You can open a TAC case online at http://www.cisco.com/tac/caseopen
If anyone else in the forum has some advice, please reply to this thread.
Thank you for posting.
Either buy some coax attenuators, or just don't screw the cable connectors in all the way.
Or you can just use a couple of rubber duck (low gain omni) antennas.
Thanks for the reply! I have some 20dB attenuators on order. I will also cut the radio power down to the lowest setting and move up as/if needed.
Thanks again!
217
