Community Member
Connecting a WET200 to a Wireless controller 4402
Hi, We Have a WLC-4402 controller with LWAPPs and different VLANs and SSIDs. I've configured a Linksys WET200 to associate to one of the SSIDs.
On the WLC I can see, that the WET200 is associated to one Wlan.
Then I connect one computer with a static IP address and works fine.
But when I connect a second one, everythiing goes down. It does not connect.
I can only connect one computer to the WET200
Do I need other seetings on the WLC to allow pass traffic through the WET200?
Can you please help?
Any Alternatives?
Thanks..
Everyone's tags (1)
Community Member
Re: Connecting a WET200 to a Wireless controller 4402
We are experiencing a similar, if not the same, issue here.  After upgrading the firmware on our WLCs, the WET200 bridges we have in place no longer allow multiple devices to function at the same time.  One device at a time will work but if multiple devices are on at the same time only one is pingable.
Did you ever find a solution to this issue?
What version of code are you running on the WLC?  If you are 5.2 >, you may want to try the following command:
config network ip-mac-binding disable
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Community Member
That was the culprit.  We had recently upgraded to v6.0.199.4 and I guess this feature was added.
After disabling ip-mac-binding, the wired clients will work if assigned a static IP address.  Still can't seem to get DHCP to work, but oh well.
Hello Jorge,
Please mark the Question as Answered, if the provided information is correct and it helped. By doing that others can take benefit as well.
Vinay Sharma
Community Manager – Wireless
Thanks & Regards
1051
