Connecting Aironet 350 to Hub
Can anybody tell me whether there are any know issues with connecting an Airenot 350 bridge, to a 10MB/HD Hub ?
I have one end of the link connecting to a Cat 2950G Swicth, with the ethernet port set to 100MB/FD and was wondering whether this setup would cause the link to be flooded at the Hub end.
Thanks.
1 REPLY
Re: Connecting Aironet 350 to Hub
I haven't actually tried that but I don't see why it should be an issue. Ultimately the bridge link is only going to perform at about 6mbps max, which is inline with the hub capability anyway. The more important issue might be the local traffic levels within the hub itself.
Surely with 10/100 switches so cheap it might be better logic to replace the hub and avoid the collision/throughput issues.
104
