connecting two 1841 using HWIC-3G-GSM
a_kalantari
Hi dear experts
I want to connect to locations using 1841 routers with HWIC-3G-GSM cards.
Is it possible I use this without connecting to GPRS and without using a profile and dierectly with AT commands?
How can I force one router to act in answer mode?
How can configure the other one to dial to second router (via its mobile number).
Thx in advance
Al
carenas123
Level 5
Level 5
Here is the URL for the Configuring the 3G Wireless High-Speed WAN Interface Card for Cisco 1841, and 2800 and 3800 Series Routers (HWIC-3G-GSM) follow the configuration guide it will help you :
http://www.cisco.com/en/US/docs/routers/access/1800/1861/software/feature/guide/3ghwic.html
Dear Carlos,
Thx for help. Actually I read document many times and tested a lot but not useful to me.
I have two 1841 routers and would like to connect them directly via GSM not through GPRS.
I have configured my ROUTER1 as Dial on Demand as you may see its config in attachment. Its ok and dials out without any problem.
I have problem in my second router config (ROUTER2) . I have attached its config too.
As you can see in attachment file, modem parameters ar ok and S0=1 which means its in auto answer mode.
When I dial from Router1 to Router2 , Router2 dosent reply and so dial fails. But when in Router2 I connect to modem (with telnet 2.2.2.1 2018) and again dial from Router1 to Router2 , it hanhup and both modems connect to each other.
I just would like to know what is my foul in ROUTER2 configuration and if you have any suggestion for it.
Thx in advance,
Alireza Kalantari
