Connection client in WEP to autonomous AP but not to AP LWAPP
In a production environment I have clients with proprietary operating system and Intel wifi card 802.11b.
The client supports only WEP128 with shared authentication type.
With an AP AP1242 mod-AIR-E-K9 version 12.3(8)JA2 and the following configuration, the client connects to AP accurately:
aaa session-id common
dot11 ssid test
authentication shared
guest-mode
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption key 1 size 128bit 7 D2663768017E3054F27A47416D4D transmit-key
encryption mode wep mandatory
ssid test
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2412
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
station-role root
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
hold-queue 160 in
interface BVI1
ip address 1.1.1.1 255.255.255.0
no ip route-cache
ip default-gateway 1.1.1.2
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
control-plane
bridge 1 route ip
Using a centralized infrastructure with controllers 4402 5.0.148.0 and LAP1242 the connection does not happen.
I created a WLANs, set Layer 2 Security: static WEP, selected WEP 104 bit, key1, I inserted a key 26 characters long HEX,
enabled field Allow Shared Key Authentication.
The rest of the parameters I let them default.
The client does not connect and remain in the status associated and Auth NO.
The WEP key is correct!
Someone has an indea?
thanks.
Mirko Severi
1 REPLY
Bronze
Re: Connection client in WEP to autonomous AP but not to AP LWAP
Mirko
Not sure why your WEP with the shared key authentication is not working, but probably no one else has tried it as WEP with open authentication the norm.
do you have a wireless sniffer to observe the authentication or looked in the event logs for any clues.
Have you tried to seting WEP Mandatory on hte controller.
you may be the only one using Shared-Key.
I suggest you open a TAC call or call the device vendor if you haven't already
Bill
186
