Connection issue of AIR-AP1141N-A-K9.
Dear all,
I have some connection trouble with AIR-AP1141N-A-K9.
I put a IP camera in my home and connect to AIR-AP1141N-A-K9 via wireless.
After a while about 1 week, the wireless will be dissociated.
Does anyone have the same issue of wireless?
Below are some information & log message of AP.
Please give me some suggestion to resolve this issue, thanks.
AP information
Product/Model Number: AIR-AP1141N-A-K9
Top Assembly Serial Number: FTX1533KDNF
System Software Filename: c1140-k9w7-tar.124-21a.JA1
System Software Version: 12.4(21a)JA1
Bootloader Version: 12.4(23c)JA1
System Uptime: 3 days, 2 hours, 39 minutes
Log message
sh syslo               loo   gg
SEKISUI_184#sh logging
Syslog logging: enabled (1 messages dropped, 2 messages rate-limited,
                0 flushes, 0 overruns, xml disabled, filtering disabled)
    Console logging: level debugging, 84 messages logged, xml disabled,
                     filtering disabled
    Monitor logging: level debugging, 0 messages logged, xml disabled,
                     filtering disabled
    Buffer logging: level debugging, 84 messages logged, xml disabled,
                    filtering disabled
    Logging Exception size (4096 bytes)
    Count and timestamp logging messages: disabled
    Trap logging: level informational, 85 message lines logged
--More--
Log Buffer (4096 bytes):
6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f07d.6806.287a Reason: Sending station has left the BSS
May 18 16:03:56: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   f07d.6806.287a Associated KEY_MGMT[NONE]
May 18 16:04:39: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f07d.6806.287a Reason: Sending station has left the BSS
May 18 16:04:44: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   f07d.6806.287a Associated KEY_MGMT[NONE]
May 18 16:06:08: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f07d.6806.287a Reason: Sending station has left the BSS
May 18 16:06:13: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   f07d.6806.287a Associated KEY_MGMT[NONE]
May 18 16:40:27: %DOT11-4-MAXRETRIES: Packet to client f07d.6806.287a reached max retries, removing the client
May 18 16:40:27: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f07d.6806.287a Reason: Previous authentication no longer valid
May 18 16:40:42: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   f07d.6806.287a Associated KEY_MGMT[NONE]
May 18 16:43:03: %DOT11-4-MAXRETRIES: Packet to client f07d.6806.287a reached max retries, removing the client
--More--                           May 18 16:43:03: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f07d.6806.287a Reason: Previous authentication no longer valid
May 18 16:43:18: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   f07d.6806.287a Associated KEY_MGMT[NONE]
May 18 16:45:35: %DOT11-4-MAXRETRIES: Packet to client f07d.6806.287a reached max retries, removing the client
May 18 16:45:35: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f07d.6806.287a Reason: Previous authentication no longer valid
May 18 16:45:50: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   f07d.6806.287a Associated KEY_MGMT[NONE]
May 18 16:48:01: %DOT11-4-MAXRETRIES: Packet to client f07d.6806.287a reached max retries, removing the client
May 18 16:48:01: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f07d.6806.287a Reason: Previous authentication no longer valid
May 18 16:49:43: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   f07d.6806.287a Associated KEY_MGMT[NONE]
May 18 17:00:37: %DOT11-4-MAXRETRIES: Packet to client f07d.6806.287a reached max retries, removing the client
--More--                           May 18 17:00:37: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f07d.6806.287a Reason: Previous authentication no longer valid
May 18 17:03:39: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   f07d.6806.287a Associated KEY_MGMT[NONE]
May 18 17:10:12: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f07d.6806.286e Reason: Sending station has left the BSS
May 18 17:10:12: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   f07d.6806.286e Associated KEY_MGMT[NONE]
May 18 17:10:30: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f07d.6806.286e Reason: Sending station has left the BSS
May 18 17:10:35: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   f07d.6806.286e Associated KEY_MGMT[NONE]
May 18 17:10:54: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f07d.6806.286e Reason: Sending station has left the BSS
May 18 17:11:00: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   f07d.6806.286e Associated KEY_MGMT[NONE]
May 18 17:15:23: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station f07d.6806.286e Reason: Sending station has left the BSS
May 18 17:15:29: %DOT11-6-ASSOC: Interface Dot11Radio0, Station   f07d.6806.286e Associated KEY_MGMT[NONE]
SEKISUI_184#    =
Everyone's tags (1)
1 REPLY
Hall of Fame Super Gold
f07d.6806.286e
Is this the MAC address of your wireless camera?  A D-Link?
If this is so, can I ask you to post the output to the command "sh dot11 assoc f07d.6806.286e"?
1007
