connectivity between devices in mesh
What is the ideal way to check connectivity & wireless strength between mesh devices like root acces point and maps, work group bridges.
this is to verify if the devices are able to transmit optimally in case there is any hard obstructing surfaces or sight problems.
Please suggest.
Thanks .
1 ACCEPTED SOLUTION
Re: connectivity between devices in mesh
If you have WCS you can use it. You can check mesh links health.
From WCS go to Monitor->Access Points. then click on your AP name then click on your AP radio type.
see the image below.
If you don't have WCS it will be harder. You can ssh to the AP and issue some commands like:
- show mesh adjacency all.
- show mesh status.
Amjad
Rating useful replies is more useful than saying "Thank you"
1 REPLY
- show mesh status.
Amjad
300
