Console configuration LWAPP AP 1240
Hello
How can I manually alter the IP settings of LWAPP Aironet 1240AG on the console?
Pascal
1 REPLY
Hall of Fame Super Red
Re: Console configuration LWAPP AP 1240
Hi Pascal,
Maybe this info will help;
Manually Configuring Controller Information Using the Access Point CLI
In a new installation, when your access point is unable to reach a DHCP server, you can manually configure needed controller information using the access point CLI.
Note The CLI commands in this section can be used only on an access point that is not associated to a controller.
The static information configured with the CLI commands are used by the access point to connect with a controller. After connecting with the controller, the controller reconfigures the access point with new controller settings, but the static IP addresses for the access point and the default gateway are not changed.
To manually configure controller information on a new (out-of -the-box) access point using the access point CLI interface, you can use these EXEC mode CLI commands:
AP# lwapp ap ip address
AP# lwapp ip default-gateway IP-address
AP# lwapp controller ip address IP-address
AP# lwapp ap hostname name
Where name is the access point name on the controller.
Note The default (out-of-box) Enable password is Cisco.
Clearing Manually Entered Controller Information
When you move your access point to a different location in your network, you must clear the manually entered controller information to allow your access point to associate with a different controller.
Note This command requires the controller configured Enable password to enter the CLI EXEC mode.
To clear or remove the manually entered controller information, you can use these EXEC mode CLI commands:
clear lwapp ap ip address
clear lwapp ip default-gateway
clear lwapp controller ip address
clear lwapp ap hostname
Manually Resetting the Access Point to Defaults
You can manually reset your access point to default settings using this EXEC mode CLI command:
clear lwapp private-config
From this good LWAPP 1240 doc;
http://www.cisco.com/en/US/products/ps6521/products_installation_guide_chapter09186a008079b730.html#wp1082991
Hope this helps!
Rob
Please remember to rate helpful posts.....
1405
