Community Member
Constantly Awake Mode. How do I select this?
I am using LXE MX3X terminals with Cisco 350 radios and Cisco 1200 Access Points. When I go into the Aironet Client Utility under the profiles tab, my active profile is <External Settings>. How do I select CAM mode when I am using <External Settings>?
1 REPLY
Bronze
Re: Constantly Awake Mode. How do I select this?
The System Parameters screen enables you to set parameters that prepare the client adapter for use in a wireless network. This screen appears after you create and save a new profile or click Edit on the Profile Manager screen.
For more information refer to
http://www.cisco.com/en/US/products/hw/wireless/ps4555/products_installation_and_configuration_guide_chapter09186a008031a945.html#wp1159812
195
