Controler 2100 Series and licences
coye97400
How should I proced to, migrate my controler 2112 to a 2125 licences ?
does it exist a documentation to do that ?
thkx
Rob Huffman
Hi Alain,
Jeffrey is most correct here (+5"J")
Here is a Cisco reference that speaks to this question;
Q. Is it possible to increase the support of access points with a software upgrade?
A. No, the Cisco 2112 and 2125 require new hardware to support 12 and 25 access points
From this good Q & A;
http://www.xbridgeservices.com/UserFiles/File/cisco_2100.pdf
Cheers!
Rob
Jeffrey Keown
Hi, there aren't licenses for 2100 series controllers, nor is there a software upgrade path.
You'll need to replace the 2112 with a 2125 if up to 25 ap's are required.
Are you sure ? because i found some Reseller who propose a licence for 7
000 euros...
Rob Huffman
Hi Alain,
Cheers!
Rob
