01-14-2014 04:05 AM - edited 07-04-2021 11:57 PM
Are any of the following wireless software (5500 controller) releases compatibile with cisco prime 2.0 ?
- 7.4.121.0
- 7.6.100.0
M.
Solved! Go to Solution.
01-14-2014 04:14 AM
HI,
Cisco PI 2.0 supports:
Cisco 5500 Series | 7.0 through 7.4.110.0 |
http://www.cisco.com/en/US/docs/net_mgmt/prime/infrastructure/2.0/release/notes/cpi_rn.html
Your both software not supported by PI 2.0.
May be PI 2.1 will support both these software in future.
01-14-2014 04:14 AM
HI,
01-14-2014 04:15 AM
For 7.4 and 7.6 support, you want to run PI 1.4
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
01-14-2014 04:16 AM
They will work. The v7.4 is compatible, but v7.6 is fully supported in PI 1.4.1 and PI 2.1 which is not out. I have PI 2.0 and WLC v7.6, but Cisco doesn't support v7.6 unless you use PI 1.4.1 or wait for PI 2.1.
01-14-2014 04:30 AM
Tx, but narrowing the discussion to using compatible releases (ONLY) between prime and 5500 controller sw it seems that I am stuck upto 7.4.100.0 for the moment. Thanks to all who responded and/or provided usefull links.
M.
01-14-2014 05:40 AM
PI 2.0 can work with WLC v7.6 as I have that running. The 3700's are only supported in PI 1.4.1 and PI 2.1.
01-14-2014 06:25 AM
Hmm, define 'can work' and 'have running' ; it is not because we see some good looking menu's that things 'work';
anyway it contradicts cisco's viewpoint on these matters.
M.
01-14-2014 06:45 AM
Well if you have been around there for a while, then you know that these are not 100%. So does PI work well with v7.6, for me it does. Look at Leo who is also on the forum. He has WCS still managing WLC v7.5. You should test it for yourself. Bring up PI 2.0 and PI 1.4.x. You can rehost the license and run them in parallel.
01-14-2014 06:50 AM
PI 1.4.1 supports both code
http://www.cisco.com/en/US/docs/net_mgmt/prime/infrastructure/1.4/release/notes/cpi_rn_141.html#wp86690
