Community Member
Converged Access MA and MC licensing
Hello all,
one question regarding the licensing for converged access. If I understand it correctly then when I have a deployment in which I already have a WLC (mobility controller) and I deploy a 3650/3850 switch as a mobility agent, then the AP count licensing needs to be maintained on the MC (WLC) and I dont need AP count licences on the MA (3650/3850)?
Then the only thing I need is to point the MA to the MC IP address and I gain the benefits of converged access architecture (CAPWAP termination ...)?
Thank you.
Marek
1 ACCEPTED SOLUTION
VIP Purple
Yes, You got the answer..
Yes, You got the answer.. Licence only required for MC.
Rasika
Community Member
I probably found the answer
I probably found the answer in this document:
http://www.cisco.com/c/en/us/products/collateral/wireless/5700-series-wireless-lan-controllers/qa_c67-726397.html
Q. Do I need a wireless access point license on both the mobility agent and the mobility controller?
A. The license to manage access points is only needed on the mobility controller.
Marek
VIP Purple
Rasika
463
