Converted AP 1121g to LWAPP
I converted an AP 1121g to Lwapp sucessfully (so it seems) using the Lwapp conversion tool. Once rebooted the WCS only sees the AP sporadically and then the AP drops from view only to show up again with a different AP ID. When it does show I can attempt to reassign some of the details but when I attempt to save the changes the AP drops again. Did I do something wrong in the conversion? Any thoughts!
Silver
Re: Converted AP 1121g to LWAPP
Hi Daniel,
maybe the Messages from the Logs may give us some hints here. Please post them.
Aware from that: Often the problems within the conversion is the time setting. If the Controller and the AP have different time settings the certificate cannot be accepted as valid and the controller does not associate.
Best regards,
Frank
Below is a copy of the message log. Appreciate your input on this one.
Tue Nov 7 14:58:03 2006 [ERROR] spam_api.c 413: Slot ID 0 is not valid for AP 00:11:21:E2:53:FE
Tue Nov 7 14:57:02 2006 [ERROR] spam_lrad.c 2688: Security processing of Image Data failed from AP 00:11:21:e2:53:fe
Tue Nov 7 14:57:02 2006 [ERROR] spam_crypto.c 653: Failed decryption of message from AP 00:11:21:E2:53:FE
Tue Nov 7 14:57:01 2006 [ERROR] spam_lrad.c 2688: Security processing of Image Data failed from AP 00:11:21:e2:53:fe
Silver
Hi Daniel,
be sure that the country settings of the WLC matches the country settings of the AP.
What WCS Software Version do you use?
Best regards,
Frank
Version 3.2.150.6. The WCS country is set to US.
Hall of Fame Super Red
Hi Daniel,
This may be way off base, but what version are running on the WLC? Support for the AP1121 was only added this past summer in version 4.0.155.0
Have a look at this note for 4.0.155.5 (use this)
Hope this helps!
Rob
Please remember to rate helpful posts.....
My bad! Here is the link to the release notes :)
http://www.cisco.com/en/US/products/ps6366/prod_release_note09186a00806e8989.html#wp147320
Hope this helps!
Rob
Silver
Hi Daniel,
nothing else to add to Robs analysis. Upgrade the WLC and it will work fine.
Have good luck.
Best regards,
Frank
I am planning to upgrade the controller this evening. I missed this upgrade announcement along the way. Looks like this could be the answer. I will post the results once completed.... Thanks!
Frank and Rob,
Thanks for the help. I upgraded the conroller and the AP came up with no problem.
209
