02-07-2007 12:35 PM - edited 07-03-2021 01:35 PM
I have several AP 1231 which I want to use with wireless Lan controller. Whenever I try to upgrade the IOS I get the error message 'AP does not have Supported Radio'
Well I know that the A radio(RSM20A) is not supported, but b/g is!(MP21G).
Is it possible to upgrade to LWAP with b/g only? and how can I do it?
Thank
Michael
Solved! Go to Solution.
02-07-2007 12:48 PM
Remove the A radio and retry, and make sure you are using the IOS to LWAPP upgrade tool.
02-07-2007 01:02 PM
Hi Michael,
Have you tried removing the A radio before running the upgrade?
Rob
02-07-2007 12:48 PM
02-07-2007 01:02 PM
Hi Michael,
Rob
02-09-2007 02:55 PM
Certainly not! that would be too easy ;)
Michael
