CSCse38065 - Memory leak in hapi buffer (WiSM/4400)
wififofum
Level 4
Level 4
Anyone seen this? have had it happen once on 3 different controllers. After it happened recently on 1st WiSM WLC, APs joined the first WiSM WLC in their Mobility Group list (mWar list), until this controller had the same issue. APs did not appear to try to go elsewhere (or controller could not respond to tell them). Controllers could not be accessed by any means until they were rebooted. After which all was well and AP Fallback kicked in.
CSCse38065 Bug Details
Headline Memory leak in hapi buffer pool 0
Product ct4000-4100
Feature OTHERS Duplicate of
Severity 2 Severity help Status Unreproducible Status help
First Found-in Version
3.2(116.21), 4.0(179.11) First Fixed-in Version Version help
Release Notes
Symptom:
May lose all access to controller, except through console. output on console:
User:mmc_buff.c 210: In hapiMmcBuffMalloc() call to 'bufferPoolAllocatemmc_buffe
User:mmc_buff.c 210: In hapiMmcBuffMalloc() call to 'bufferPoolAllocatemmc_buffl
Workaround:
Power cycle controller
wong34539
Level 6
Level 6
Sometimes upgrading the controller might be the issue.Rather than downgrading rebooting would as mentioned in the workaround would be the best otpion.
