Current firmware for HWIC 3G-GSM
Hi all
I am trying tu update the firnmware of a HWIC 3G-GSM within an 1841.
What is the correct firmware?
I have tried
K2_0_7_35 and K1_0_2_18 from
http://tools.cisco.com/support/downloads/go/Model.x?mdfid=281295483&mdfLevel=Sub-Category&treeName=Wireless&modelName=Cisco%203G%20Wireless%20WAN%20%28GPRS%2FEDGE%2FUMTS%2FHSDPA%29%20High-Speed%20Wan%20Interface%20Card&treeMdfId=278875243
and I have also tried
F1_2_3_22 from
http://tools.cisco.com/support/downloads/go/Model.x?mdfid=282745088&mdfLevel=Sub-Category&treeName=Wireless&modelName=Cisco%203G%20Wireless%20WAN%20%28GPRS%2FEDGE%2FUMTS%2FHSDPA%2FHSUPA%29%20Interface%20Card&treeMdfId=278875243
But whenever I issue
microcode reload cellular 0 1 gsm modem-provision
I get
Modem returned following error to Download Start Request:Wrong image for this product
So what might be wrong here?
Thanks for any hint,
Grischa
#sh cellular 0/1/0 hardware
Modem Firmware Version = H1_0_0_7MCAP G:/WS/
Modem Firmware built = 10/26/06
Hardware Version = 1.0
International Mobile Subscriber Identity (IMSI) = 00000
International Mobile Equipment Identity (IMEI) = 352678010376751
Factory Serial Number (FSN) = X28059709101016
Modem Status = Online
Current Modem Temperature = 41 deg C, State = Normal
#sh inventory
NAME: "chassis", DESCR: "1841 chassis"
PID: CISCO1841         , VID: V05 , SN: FTX1145W2RN
NAME: "WIC 1", DESCR: "3G WWAN HWIC-HSDPA/UMTS/EDGE/GPRS-850/900/1800/1900/2100MHz"
PID: HWIC-3G-GSM       , VID: V01 , SN: FOC11321GWG
Everyone's tags (3)
1 ACCEPTED SOLUTION
Silver
Re: Current firmware for HWIC 3G-GSM
Hi Grischa,
Did you extract the firmware before the upgrade?
archive tar /xtract source-url destination-url
Can you post the log of the whole process?
Do you have the same results with a H firmware, for example H1_1_9_33 ?
Cheers
Marco
Silver
Hi Grischa,
Cheers
Marco
Hi Marco
thank you very much. With H1_1_9_33 the update went through without any problem.
What is the difference between K and H? The latest H release is quite old compared with the K one.
And how should one know that H is correct and K is not?
Best regards,
Grischa
Silver
Hi Grischa,
I'm glad it helped!
H releases are for HWIC-3G-GSM, while K releases are for the new HWIC-3G-HSPA. The two cards have different hardware, and the firmwares are not compatible.
H2_0_8_19 is the latest one for your card. However, I'd suggest to do this upgrade only if stricly necessary: on HWIC-3G-GSM, if you upgrade to 2.x.x firmware, you cannot roll back to version 1.x.x
Cheers!
Marco
Thanks Marco. I dont know why Cisco keep making things difficult!! They should seperate them in the download section.
Hi Marco,
I maybe a bit off the topic,but I got a hwic-3g-gsm card but I'm failing to change the band it came with ,the firmware it is showing is H1_1_9_3MCAP C:/WS/,should I upgrade to be able to do anything?
Is there a way of reseting the card to factory defaults ?
Silver
Which steps are you following to change band? Perhaps you can paste the logs.
An upgrade can help, although we cannot be sure.
Marco
4813
