09-24-2014 08:16 AM - edited 07-05-2021 01:35 AM
hello,
I have a small problem with the construction of a mobility group.
My network consists of two WLC ( 5508 and 2504) Ver 7.6.100
If I create the mobility group , the data and control path doesn't come up. The two controllers has management interface in the same subnet.
Ping work, Mping don't work.
Has anyone an idea ?
Greeting from Germany
Juergen
09-24-2014 08:57 AM
can you post the output of "show mobility summary" from both the controllers?
Steve
09-24-2014 01:52 PM
Check whether both WLC configured with same virtual IP address as well
Rasika
*** Pls rate all useful responses ****
10-07-2014 05:42 AM
The problem has been solve by uncheck " new mobility"
10-07-2014 11:22 AM
Thanks for the follow up & post the resolution you got..
