Community Member
Data rate will not exceed 54 Mbps when WEP or TKIP encryption is configured
Just playing around with some wireless cards and found having issues with getting high speed with 802.11n.
After looking found can't get high speeds becouse we are still using WEP-TKIP encrytion.
This is ther becouse of XP SP2 limitations many moons ago
Our config on WLC
802.1x
with WEP-TKIP
WPA2-AES
We can remove the WEP-TKIP from the group policy for windows.
I want to double check and get a 100% right is the this will allow a device to connect via WEP-TKIP or WPA2-AES.
So removing the setting from the group policy will so only laptops connect via wpa2-aes will still work if I leave these WEP-TKIP in when the windows device only has wpas-aes settings?
cheers
Everyone's tags (5)
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: Data rate will not exceed 54 Mbps when WEP or TKIP encryptio
802.11n only supports open authentication or the use of WPAv2 with AES. Having both WPA v1/TKIP and WPA v2/AES on the same SSID has been known also to cause issues with WLCs. If you have devices that only support WPA v1/TKIP, then there is nothing you can do for those devices. They are two different encryption types... If you remove WPA/TKIP then clients that are configured to use that will not connect to WPAv2/AES.
-Scott
-Scott
Community Member
Hi Scott
Thanks for that, this was left in for the legacy laptop and PDAs, that are no longer on the wlan.
just need to change the group policy for change them to wpa2-aes only instead of iether.
Just didn't want 800 devices have to connect to the lan and force a group policy via gpupdate.
Cheers
Sometimes it's better to create a new SSID so you can migrate users to that new on and eventually decommission the old SSID. The issue with pushing out group policy to change the existing is what happens when users are not in the office or their device doesn't support WPA v2/AES. Now your help desk will be stuck working with these users. If you push out another wireless profile and put the new one as priority, well then you still have the old SSID to fall back to. The issue with pushing out a new SSID also is you need to determine what devices can support WPA v2/AES and maybe only push the policy to those devices.
-Scott
3305
