Degradation of network perf. after installing firmware 12.00t on AP350
Has anyone else noticed a noticeable slow down after updating to firmware 12.00t? I also enabled WEP at the same time so I backed that out thinking it was the problem but network performance is still not good.
TIA
Bronze
Re: Degradation of network perf. after installing firmware 12.00
I have not really seen an issue with the 12.0T code. I have seen in the past that when things do not work properly, you need to default the AP back to the default config and start over. There might have been something that changed in the configuration when you upgraded. You could try going back to the last firmware to see if the issue goes away.
We are using ap350's and ap1200's with the 12.00T image and it seems to be working just fine. I know this sounds simplistic but look at the connectivity on the ether side of the point, as you know auto negotiation dosen't work all the time.
Jim D.
123
