Dell 1300 USB adapter
I have a Dell GX280 with a Dell 1300 series USB wireless adapter. I am using a 1230 series access point. The switchport that the AP is connected to is a trunk port. If there is no vlan assigned to the SSID, the pc will associate and get an IP address on the native vlan. Whe I assign a vlan to the SSID, the pc will associate but will not get an IP address. I have a Dell Latitude laptop with a 1450 series wireless adapter that works fine. It will get an IP address from the appropriate scope that is assoc. to the vlan. I can even assign multiple SSID's with different vlan assignments on the AP, and connect to each one using the laptop and I get the correct IP assignment from each vlan. I spoke with Dell tech support on this and they said it's a Cisco issue. I'm not buying that since the 1450 adapter works. Also, under the association menu on the ap, the 1300 adapter shows up as device type ap1200-Rptr and is listed as a repeater, the 1450 adapter shows up as 4500-radio and is listed as a client. Any suggestions?
1 ACCEPTED SOLUTION
Hall of Fame Super Red
Re: Dell 1300 USB adapter
Hi Brandon,
Here are links to a couple of previous threads that deal with this issue.Both Edgar and KaSing from Cisco seem to indicate the same solution:
Please disable Aironet Extension on the AP. i.e. go to the http interface of the AP. click on "Express Setup" You should be able to disable Aironet Extension there.
Here are the two links:
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=General&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dd6e104
http://forum.cisco.com/eforum/servlet/NetProf?page=netprof&forum=Wireless%20-%20Mobility&topic=General&CommCmd=MB%3Fcmd%3Dpass_through%26location%3Doutline%40%5E1%40%40.1dd812de
Hope this helps!
Rob
Please remember to rate helpful posts.......
Hi Brandon,
Hope this helps!
Rob
thanks Rob, that worked.
130
