NetStumbler is a tool for Windows that allows you to detect Wireless Local Area Networks (WLANs) using 802.11b, 802.11a and 802.11g.
Here are some key features of "NetStumbler":
⢠Verify that your network is set up the way you intended.
⢠Find locations with poor coverage in your WLAN.
⢠Detect other networks that might be causing interference with your network.
⢠Detect unauthorized "rogue" access points in your workplace.
⢠Help aim directional antennas for long-haul WLAN links.
⢠Use it recreationally for WarDriving.
