DHCP on Air1230B on guest VLAN
Hi everybody,
I need to solve specific problem. I'm trying to create two SSIDs on my AP. The first for corporate users(encrypted) and the second FreeAccess.
All IP addresses and information are not final - it's LAB so far.
SSID
1.CorporateWLAN - encrypted, full access
2.FreeAccess - w/o encryption, guest-mode, only browsing(filters not included in following current-config)
I want to achieve assignement of IP adresses to wireless clients from AP(DHCP server on AP) but only to guestVLAN(VLAN ID 2) users.
BTW VLAN1 is native VLAN.
Interface's addresses are excluded from DHCP pool.
I'm not a pro in this area so all comments will be appreciated.
BTW again :), this config doesn't work.
CONFIG:
AP_TEST#sh run
*Mar 1 01:36:44.699: %SYS-5-CONFIG_I: Configured from console by console
Building configuration...
Current configuration : 2096 bytes
version 12.2
no service pad
service password-encryption
hostname AP_TEST
logging queue-limit 100
enable secret xxx
username xxx password xxxx
ip subnet-zero
ip dhcp excluded-address 10.5.5.1 10.5.5.5
ip dhcp excluded-address 192.168.1.215 192.168.1.220
ip dhcp excluded-address 192.168.1.1 192.168.1.5
ip dhcp pool DHCPVLAN2
network 10.5.5.0 255.255.255.0
default-router 192.168.1.1
domain-name LAB
dns-server 10.5.5.3
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 key 1 size 128bit xxxxx
transmit-key
encryption vlan 1 mode wep mandatory
ssid CorporateWLAN
vlan 1
authentication open
ssid FreeAccess
vlan 2
authentication open
guest-mode
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
rts threshold 2312
channel 2462
station-role root
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface FastEthernet0.1
no ip route-cache
bridge-group 1
no bridge-group 1 source-learning
interface FastEthernet0.2
no ip route-cache
bridge-group 2
no bridge-group 2 source-learning
interface BVI1
ip address 192.168.1.220 255.255.255.0
no ip route-cache
interface BVI2
ip address 10.5.5.1 255.255.255.0
no ip route-cache
ip default-gateway 192.168.1.1
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag/122-15.JA/1100
ip radius source-interface BVI1
bridge 1 route ip
line con 0
line vty 0 4
login local
line vty 5 15
login
end
  • Other Wireless - Mobility Subjects
Re: DHCP on Air1230B on guest VLAN
1. RTFM :)
2. create SSID then assign it to dot11 X interface i.e. something like that:
ssid CorporateWLAN
vlan 1
authentication open
ssid FreeAccess
vlan 2
authentication open
guest-mode
ssid CorporateWLAN
ssid FreeAccess
your config dosen't work because you create 2 SSID on one interface, IMHO
3. RTFM again :)
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1200/accsspts/b1237ja/i1237sc/s37scg.pdf
http://www.cisco.com/univercd/cc/td/doc/product/wireless/airo1100/accsspts/i1237ja/cr1237ja/cr37_p.pdf
helps you
Good opinion - but SORRY doesn't work ;o)
As you stated, read the following material, more exactly pictures sol01.jpg and sol02.jpg.
Association of SSID's to radio sub-if is impossible in my version of IOS. As you can see on theese pictures there are 2 ways of configuring multiple SSIDs.
1. Interface-level configuration 12.2-prior
2. Global-level configuration - IOS 12.3 and higher
In my "shrun" as you has seen are SSID's configured properly(I think :) after reading materials from your links)- by interface-level style.
Screenshot scr01.jpg claims imposibility of sub-if SSID configuration.
BTW, thanks a lot for your time.
But it seems, that I am at the end of my knowledge about wireless configuration - and problem isn't solved :-(
Silver
Try using:
"default-router 10.5.5.1", i.e., ip address from the default router of this subnet, under "ip dhcp pool DHCPVLAN2" configuration.
Hope this helps
190
