DHCP Server in the Aironet 1520
Hi Everyone,
I have a 1250 AP connected to an Switch Cisco 3750. We have a SSID(vlan 1 - native) which get an IP Adress from our DHCP Server(located in a Windows 2003 server).
I added a new SSID in VLAN 2 and I would like no to use the DHCP Server but to make the AP get an IP Address from the pool I created in the own AP (ip dhcp pool Guest) but everytime I try to connect the new vlan, it doesnt get an ip address.
Follow the settings of the AP. Any help, it would be very appreciate.
version 12.4
no service pad
hostname BETA
enable secret 5 $1$65KK$cvnK849DOoWzq8QiMA9On.
no aaa new-model
no ip dhcp use vrf connected
ip dhcp excluded-address 10.150.4.1
ip dhcp pool Guest
network 10.150.4.0 255.255.255.0
default-router 10.150.1.1
dns-server 10.150.1.48
domain-name xxx
dot11 ssid GUEST
vlan 2
authentication open
mbssid guest-mode
dot11 ssid INTERNAL
vlan 1
authentication open
mbssid guest-mode
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 1 key 1 size 128bit 7 BD4BDA5C243413C59A1115891509 transmit-key
encryption vlan 1 mode wep mandatory
encryption vlan 2 key 1 size 128bit 7 BD4BDA5C243413C59A1115891509 transmit-key
encryption vlan 2 mode wep mandatory
ssid GUEST
ssid INTERNAL
mbssid
station-role root
interface Dot11Radio0.1
encapsulation dot1Q 1 native
no ip route-cache
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.2
encapsulation dot1Q 2
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
encryption key 1 size 128bit 7 FC38FBE1CFEC896823254FB402C4 transmit-key
encryption mode wep mandatory
antenna gain 4
no dfs band block
channel width 40-below
channel dfs
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
interface GigabitEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
interface GigabitEthernet0.1
no ip route-cache
bridge-group 1
interface GigabitEthernet0.2
no ip route-cache
bridge-group 2
interface BVI1
ip address 10.150.1.122 255.255.0.0
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
snmp-server community Public RO
bridge 1 route ip
1 ACCEPTED SOLUTION
go under the vlan 2 interface and do a no shut
also take a look at a show vlan brief and make sure that vlan 2 is there.  if it's not,
conf t
vlan 2
and that should build the vlan at L2
HTH, Steve ------------------------------------------------------------------------------------------------ Please remember to rate useful posts, and mark questions as answered
Re: DHCP Server in the Aironet 1520
Fernando,
To use the DHCP server on the ap, you'll need to point an ip helper address on the L3 interface, and point it at the IP of the AP. Otherwise the AP wouldn't know which scope to give the client.
Stephen,
I set the gigabit ethernet 0.2 of my AP with ip helper-address 10.150.1.122 and the problem persists.
Have I made something wrong?
Thanks and sorry for the poor knowledgment techinical.
Fernando
  All the guest traffic is going to be bridged down into VLAN 2 by the AP, and doesn't require an IP address.  The ip helper needs to go on the L3 interface of the network, so where ever the routing is happening for VLAN 2.
HTH,
Steve
Stephen,
I have the following topology on my network:
Cisco AP <-------------> Switch 3750 <--------------------> Cisco Pix<------------------>Internet Router<------------> Internet
10.150.1.122               10.150.1.102                        10.150.1.1
                                  (enabled ip routing)
Our default-gateway in the network is usually the 10.150.1.1. Should I use it?
Thank you very much.
Fernando
That wouldn't work, as it's not the same subnet as the guest, and looking at the guest scope, the default-router should be in the 10.150.4.0/24 subnet range.
So you would need an interface on either on the pix, or on the 3750 in VLAN 2.  This is where you would need to put the ip helper.
Stephen,
I changed the scope of my new range because it was overlapping with vlan 1 native. Well, I set the ip address of interface vlan 2 on my switch l3 3750 to 10.152.0.1 and set the ip helper-address to 10.150.1.122(ip address of the AP where is the DHCP pool). My laptop coulnt get the ip address.
Remenber I enabled "ip routing" on 3750 switch. Follow the config. The AP is connected in the Gi 1/0/16 port.
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname BR-SW-02
no aaa new-model
clock timezone UTC -3
switch 1 provision ws-c3750g-24t
system mtu routing 1500
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet1/0/16
switchport trunk allowed vlan 1,2
switchport mode trunk
interface Vlan1
ip address 10.150.1.102 255.255.0.0
interface Vlan2
ip address 10.152.0.1 255.255.0.0
ip default-gateway 10.150.1.1
ip classless
ip http server
it wouldn't have, the scope you have defined on the AP is not the same scope as what you configured for VLAN 2.
ip dhcp pool Guest
You would need to change the scope on the AP to match the address on VLAN 2 on the switch
so:
conf t
no ip dhcp pool Guest
network 10.152.0.0 /16
default-router 10.152.0.1
exit
wr
and that should fix you up.
HTH,
Steve
Stephen,
Everything seems to be fine but even all, my new ssid still cant get the correct ip address. I noted the my interface vlan 2 on the switch 3750 is down. Is it correct?
BR-SW-02#sh interfaces vlan 2
Vlan2 is down, line protocol is down
  Hardware is EtherSVI, address is 68bd.ab34.1ec1 (bia 68bd.ab34
  Internet address is 10.152.0.1/16
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
     reliability 255/255, txload 1/255, rxload 1/255 BR-SW-02#sh interfaces vlan 2
I have no device connected in this vlan.
Thanks for your patience and support.
Fernando
conf t
vlan 2
thank you very much for your support.
Now I am facing a new problem which is related in other post. If you could help me, I will be really thankful.
Thanks a lot.
Fernando
569
