DHCP VCI for AIR-LAP 1242 AG
hi forum,
I need to configure this DHCP option 43. I am using cisco aironet 1242 AG, my supplier told me i have to use the VCI : Airespace.AP1200, but I found it on the web site that I have to use the VCI: Cisco AP c1240. which one is correct coz my supplier insist I use Airespace.AP1200.
py
2 ACCEPTED SOLUTIONS
Re: DHCP VCI for AIR-LAP 1242 AG
Hi Friend,
c1240 is the one which you should use
Access Point Model (VCI)
Cisco 1000 Series Airespace.AP1200
Cisco 1130 Series Cisco AP c1130
Cisco 1240 Series Cisco AP c1240
Cisco 1200 Series Cisco AP c1200
Ankur
*Pls rate all helpfull post
Hall of Fame Super Red
Hi Paul,
I just wanted to add a short note to Ankur's excellent info. Here are two docs that support this;
AP VCI String
Aironet 1130 Series - Cisco AP c1130
Aironet 1240 Series - Cisco AP c1240
Aironet 1200 Series - Cisco AP c1200
From this doc;
http://www.cisco.com/en/US/products/ps6306/products_qanda_item09186a00806a4da3.shtml
Cisco Aironet 1000 series
Airespace.AP1200
Cisco Aironet 1100 series
Cisco AP c1100
Cisco Aironet 1130 series
Cisco AP c1130
Cisco Aironet 1200 series
Cisco AP c1200
Cisco Aironet 1240 series
Cisco AP c1240
Cisco Aironet 1300 series
Cisco AP c1300
Cisco Aironet 1500 series
Cisco AP.LAP1510
From this doc;
http://www.cisco.com/en/US/products/hw/wireless/ps430/products_installation_guide_chapter09186a0080721297.html
Hope this helps!
Rob
Please remember to rate helpful posts.....
Hi Friend,
Ankur
Hi Paul,
AP VCI String
From this doc;
Airespace.AP1200
Cisco AP c1100
Cisco AP c1130
Cisco AP c1200
Cisco AP c1240
Cisco AP c1300
Cisco AP.LAP1510
From this doc;
Hope this helps!
Rob
If i am setting up dhcp on a cisco router 2600, how do i enter option 60 and option 43 commands ?
Hi Friend,
Here you go with the link
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fipras_r/1rfdhcp.htm#wp1018642
You just need to use the option command under DHCP config mode
option code [instance number] {ascii string | hex string | ip address}
Ankur
*pls rate all helpfull post
you can also use the hex calculator at :
http://www.delorie.com/store/hcalc/
this is my configuration :
ip dhcp excluded-address 192.168.121.1 192.168.121.30
ip dhcp pool AP1242
network 192.168.121.0 255.255.255.0
default-router 192.168.121.1
dns-server 172.16.160.31 172.16.160.32 172.16.150.38 172.16.209.45
option 60 ascii "Cisco APc1240"
option 43 hex f104.c0a0.7904
lease 30
I am not sure the f104.c0a0.7904 = 192.168.121.4 or not, i haven't test that out yet.
Thank you,
py
1692
