Different Gateways on Vlans?
I need to add a new SSID/VLAN to my existing access points. These already have 2 SSID/VLANs on them and are working fine.
My problem is that for the new SSID/VLAN I need to use 802.1x authentication and for that to work the Access Point needs to talk to a Radius server, which is not on the Access Points Subnet. The Access point will need to talk to the Gateway on the new SSID/VLAN, which is different to the existing Gateway, used for the existing SSID/VLANs on the Access Point.
Is there any way of adding a new Gateway (IP address?) for the new Vlan, like you can with a switch?
Cheers,
Jen.
1 REPLY
Silver
Re: Different Gateways on Vlans?
All you have to do is create sub-interfaces on the router and create VLANs on the switch and the APs. Then you can do 802.1x for the SSID with the RADIUS server on a different subnet.
120
