disabling Access Point
On my WLC that is Anchor (master) , i want that any access point can't register on. The registration of the access point must be disabled.
It is possible to do?
thanks for your help
fcostalunga
Re: disabling Access Point
Yes,
Go to security, enable AP authorization list, and enter the MAC addresses of the APs allowed on this controller. The other APs (not listed) will not be able to register to this controller.
Hope it helps
Jerome
i don't find this menu in the GUI (authorization list)
can you send me the CLI.
On the GUI , there are:
Security
--- AAA
General
RADIUS
Authentication
Accounting
--- TACACS+
Authentication
Accounting
Authorization
LDAP
Local Net Users
MAC Filtering
Disabled Clients
User Login Policies
AP Policies
--- Local EAP
General
Profiles
EAP-FAST Parameters
Authentication Priority
Priority Order
Management User
---- Access Control Lists
CPU Access Control Lists
--- Wireless Protection Policies
Trusted AP Policies
Rogue Policies
Standard Signatures
Custom Signatures
Signature Events Summary
Client Exclusion Policies
AP Authentication / MFP
Management Frame Protection
--- Web Auth
Web Login Page
Certificate
--- Advanced
this is the menu, but the Access control list not work how to explain me.
fcostalunga
In the GUI, go to Security > AP Policies, click Add to trigger the AP policies and add a new access point MAC address.
From the CLI:
config auth-list ap-policy authorize-ap enable
then
config auth-list add mic (suposing your AP has a MIC and not SSC).
Hope it helps
J
142
