Community Member
DLink Cardbus connection to AP1200
I have setup an AP1200 and client with DLink DWL-650. AP's authentication is setup as 128bit with shared key. The client is running windows 2000. The client can connect with the AP and this is verified by looking at the AP's log, I can see the IP address of the client given by a DHCP server and it shows that the client is authenticated and associated.
The problem is when I do a test (ping) from the AP to the client and vice versa it fails. Or if I ping the client from anywhere in my network it also fails.
Did I configure the AP correctly? Or do I need to do something else.
1 REPLY
Community Member
Re: DLink Cardbus connection to AP1200
When the pings timed out, was there any event logs on the AP?
139
