Do I need a BVI ?
I am editing a AP that has already been configured. The BVI1 has the proper IP address and works fine. My question is do i need this? should it be on eth1? I have the Cisco "Using VLANs with Cisco Aironet Wireless Equipment" documentation and it tells me to use eth1. I am about to add a second SSID and VLAN to these access points.
apwire#sh run
Building configuration...
Current configuration : 4884 bytes
version 12.3
no service pad
service password-encryption
hostname apwire
clock timezone UTC -5
clock summer-time UTC recurring
ip subnet-zero
ip domain name wireless
ip name-server 192.168.1.10
ip name-server 192.168.1.12
aaa new-model
aaa group server radius rad_eap
server 192.168.1.20 auth-port 1645 acct-port 1646
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
cache expiry 1
cache authorization profile admin_cache
cache authentication profile admin_cache
aaa group server tacacs+ tac_admin
cache expiry 1
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login default local
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa accounting network acct_methods start-stop group rad_acct
aaa cache profile admin_cache
all
aaa session-id common
dot11 ssid wifi
authentication open eap eap_methods
authentication network-eap eap_methods
authentication key-management wpa
guest-mode
infrastructure-ssid optional
dot11 arp-cache optional
crypto pki trustpoint TP-self-signed-1651530556
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-1651530556
revocation-check none
rsakeypair TP-self-signed-1651530556
crypto ca certificate chain TP-self-signed-1651530556
certificate self-signed 01
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
encryption mode ciphers aes-ccm tkip
ssid wifi
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0 54.0
channel 2462
station-role root
no dot11 extension aironet
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio1
no ip address
no ip route-cache
shutdown
encryption mode ciphers tkip
speed basic-6.0 9.0 basic-12.0 18.0 basic-24.0 36.0 48.0 54.0
channel 5200
station-role root bridge
antenna receive right
antenna transmit right
bridge-group 1
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.3.12 255.255.255.0
no ip route-cache
ip default-gateway 192.168.3.1
no ip http server
ip http authentication aaa
ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
ip radius source-interface BVI1
access-list 111 permit tcp any any neq telnet
snmp-server community RO
snmp-server enable traps tty
radius-server attribute 32 include-in-access-req format %h
radius-server host 192.168.1.20 auth-port 1645 acct-port 1646 key xxx
radius-server vsa send accounting
control-plane
bridge 1 route ip
line con 0
access-class 111 in
transport preferred all
transport output all
line vty 0 4
access-class 111 in
transport input all
line vty 5 15
access-class 111 in
transport input all
1 REPLY
Green
Re: Do I need a BVI ?
Yes, you do.
The BVI is the process that bridges the wireless segment to the wired segment.
There is no routing in the AP. The bridge connects wired & wireless, the BVI lets you assign an IP address for management (and probably ties in with the VLAN management system).
Good Luck
Scott
162
