does 1522 support REAP
I have deployed mesh solution in location A and now i have to install 2 unit of 1522 in location B, my WLC is currently installed at location A, can use the same controller and enable any REAP function so that i no need to buy another WLC. Both location A and Location B are connected using a lease line.
Mohan
Gold
Re: does 1522 support REAP
No, the 1520's do not support REAP or H-REAP
Hi Dan,
Thank you for your prompt reply on this matter. I really appreciate it.. cheers and thank you again.
Mohan
Hi Dan,
just a small confirmation to make it correct. each MESH AP is considered as 1/2 AP in the controller, am i correct to say this ? example i have 12 units MESH AP & 12 Units of AP1242, can i use WLC2112 to bring all the 24 Units AP.
Mohan
285
