does a 2504 WLC support mobility group with WiSM1 on 6500 Series
if a 2504 WLC support mobility group with WiSM1 on 6500 Series.
Model: WLC 2504
Software version: 7.3.101.0
Model: WiSM1
Software verion: 7.x.x.x
2 Accepted Solutions
Leo Laohoo
Yes and no.
Yes, mobility is supported.
No because I personally won't recommend inter-controller roaming.  This is more true when you're dealing with 4400/WiSM-1.  This is even more true when you've got WLC running two (or more) different codes.
Leo is right... yes and no:)  It's always better to have the WLC's on the same code, but they do support it:
http://www.cisco.com/c/en/us/td/docs/wireless/compatibility/matrix/compatibility-matrix.html#pgfId-149658
-Scott
Leo Laohoo
Yes and no.
Thanks Leo. Could you please provide cisco support document that says it is supported. I have been looking around the Cisco website for this but somehow not finding one.
-Scott
