09-26-2013 06:47 AM - edited 07-04-2021 12:57 AM
Does anyone knows?
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps12686/data_sheet_c78-720918.html
Should Cisco update this datasheet?
Solved! Go to Solution.
09-26-2013 07:45 AM
not yet, but maybe with the next release of the 3850 code it might be. You can check here
HTH,
Steve
Please remember to rate useful posts, and mark questions as answered
09-26-2013 07:45 AM
HTH,
Steve
09-26-2013 07:54 AM
It looks like it doesn't :-(
For more information have a look at below link under Troubleshooting session.
http://www.cisco.com/en/US/docs/wireless/access_point/700/quick/guide/ap700getstart.pdf
Hope that helps.
Najaf
Please rate when applicable or helpful !!!
09-26-2013 02:02 PM
NO,
3850 only support Cisco Aironet 1040, 1140, 1260, 1600 , 2600, 3500, 3600 AP models (as of 3.2.x code)
Refer table 3 of the below release note for detail
Rasika
09-27-2013 05:37 AM
Thanks guys! I hope this info will help others too!
