08-16-2012 03:55 PM - edited 07-03-2021 10:32 PM
HI:
We´re using a WLC 2504 and currently instaled AIR-LAP1252AG-A-K9, but we want to install some AP´s both 1262 and 3602, I just want to confirm that this controller really support this new AccessPoint.
Could you please confirm this issue and if neccesary upgrade version on the controller what version should we use.
Ellen Macias
Solved! Go to Solution.
08-16-2012 04:23 PM
Yes both AP are supported on the 2504.
As for the upgrade procedure take a look at the release notes. It documents the process pretty well.
Steve
08-16-2012 03:57 PM
To support both AP you would want to upgrade to the 7.2 train of code. Of recommend that you go with the latest version.
Steve
08-16-2012 04:09 PM
STEVE:
It means that both AP are supported by the 2504 WLC?
Something else, could you reply to me information about the upgrading process.
Thanks very much
Ellen
08-16-2012 04:23 PM
Steve
08-16-2012 04:08 PM
As what Steve said, the 3600 is supported in firmware 7.2.103.0. The 1260 is supported in earlier firmware.
I also agree that it's better if you use the newer firmware, 7.2.110.0.
Please be aware that the 2504 maybe able to support the 3600 but understand that if you are using 802.11n then the 2504 will severely not be able to cope with the load.
This will get even worst when the 802.11uc add-on module will be released this year.
