DOT11-3-TKIP_MIC_FAILURE_REPEATED - PEAP with 1131AG and IntelPro Wireless
I use windows XP computer with Intel Pro Wireless 2200BG Network card. I succeed to connect to network (IP DHCP received) through AP 1131, IAS authentication and TKIP encryption. But after 1 or 2 minutes, i was disconncted and syslog server received :
2006-05-19 09:50:29 Local7.Warning 172.30.31.52 120: May 19 08:33:38.549 GMT: %DOT11-4-TKIP_MIC_FAILURE_REPORT: Received TKIP Michael MIC failure report from the station 0016.6f4a.9a20 on the packet (TSC=0x0) encrypted and protected by group key.
2006-05-19 09:50:29 Local7.Warning 172.30.31.52 121: May 19 08:33:39.544 GMT: %DOT11-4-TKIP_MIC_FAILURE_REPORT: Received TKIP Michael MIC failure report from the station 0016.6f4a.9a20 on the packet (TSC=0x0) encrypted and protected by group key.
2006-05-19 09:50:29 Local7.Error 172.30.31.52 122: May 19 08:33:39.544 GMT: %DOT11-3-TKIP_MIC_FAILURE_REPEATED: Two TKIP Michael MIC failures were detected within 1 seconds on Dot11Radio0 interface. The interface will be put on MIC failure hold state for next 60 seconds.
2006-05-19 09:50:30 Local7.Info 172.30.31.52 123: May 19 08:33:39.545 GMT: %DOT11-6-DISASSOC: Interface Dot11Radio0, Deauthenticating Station 0016.6f4a.9a20 Reason: Invalid MIC
Has somebody ever seen this problem ?
Olivier
1 ACCEPTED SOLUTION
Re: DOT11-3-TKIP_MIC_FAILURE_REPEATED - PEAP with 1131AG and Int
I have been battling this problem for a few weeks. I think I fixed it with the wpa2 patch from Microsoft.
http://www.microsoft.com/downloads/details.aspx?FamilyID=2726f32f-d52b-4f84-ace8-f7fc20195769&DisplayLang=en
I do recall having seen a similar case with Cisco350's where there was a NIC driver issue. Have you confirmed that this client has the latest drivers?
unfortunatly YES from DELL web site for D410 ans Intel Pro Wireless 200BG for XP
Green
Absolutely. Go to Intel and get the latest drivers.
That reference to "60 Seconds" means that if the AP sees another MIC failure of that type within 60 seconds, it will shut down the radios for a while.
That feature of the standard can be configured, but I don't remember the command.
Good Luck
Scott
I 'm now using the latest version 9.0.4.13 but it's still disconnect.
I put holdoff timer to 1 s but i was always disconnect.
Olivier
Litte update, I put holdoff timer to 0. Still disconnect randomly with leaving BSS message.
Regards.
I had a batch of 350s go bad, they would tkip no matter the driver/firmware. Only these select few would do it. Took them out of the environment and all is good..
Should note that TKIP mic errors can also be caused by RF. I only put this in for anyone else who searchs for this error message and sees the messages across the board on a high number of nics.
Is that mean you are using WPA2 Network authentication? Or the patch work with WAP?
1636
