Community Member
: %DOT11-7-CCKM_AUTH_FAILED:
I have configured my 857w router for basic wireless access on one SSID/vlan which worked great.
I have now modified the config to include 2 SSIDS and 2 Vlans I have two questions.
When I connect to SSID Home it shows up as I have guest-mode configured but errors all the time with
000297: *Mar 10 06:21:08.435 UTC: %DOT11-7-CCKM_AUTH_FAILED: Station 0012.f0b9.87c3 CCKM authentication failed
000298: *Mar 10 06:21:08.763 UTC: %DOT11-7-CCKM_AUTH_FAILED: Station 0012.f0b9.87c3 CCKM authentication failed
The Wireless just keeps re-connecting - what in this basic config is causing this?
Also can I have both SSIDS in guest-mode or can only one be visible? I think I need the command MBSSID but this is not available to me in ssid-config
Roger
Router#sh run
Building configuration...
Current configuration : 2789 bytes
version 12.4
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
clock summer-time PCTime date Mar 30 2003 1:00 Oct 26 2003 2:00
dot11 ssid Home
vlan 2
authentication open
authentication key-management wpa
guest-mode
wpa-psk ascii 7 073B334D5E0C03004640585851
dot11 ssid Lab
vlan 1
authentication open
wpa-psk ascii 7 053F140E3149540C485744465E
no ip source-route
no ip dhcp use vrf connected
ip dhcp pool Home
import all
network 10.10.10.0 255.255.255.0
default-router 10.10.10.1
ip dhcp pool Lab
network 192.168.248.0 255.255.255.0
dns-server 172.16.2.17 172.16.2.19
default-router 192.168.248.1
ip cef
archive
log config
hidekeys
bridge irb
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
dsl operating-mode auto
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Dot11Radio0
no ip address
no ip route-cache cef
no ip route-cache
encryption vlan 1 mode ciphers tkip
encryption vlan 2 mode ciphers tkip
ssid Home
ssid Lab
speed basic-1.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
station-role root
no cdp enable
interface Dot11Radio0.1
encapsulation dot1Q 1
no ip route-cache
no cdp enable
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
interface Dot11Radio0.2
encapsulation dot1Q 2 native
no ip route-cache
no cdp enable
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 spanning-disabled
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
interface Vlan1
description Home
no ip address
ip tcp adjust-mss 1452
bridge-group 1
interface Vlan2
description Lab
no ip address
bridge-group 2
interface BVI1
description $ES_LAN$
ip address 192.168.248.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
interface BVI2
ip address 10.10.10.1 255.255.255.0
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
scheduler max-task-time 5000
end
Router#
257
