Dual-band Omni External Antenna
Can someone recommend me a dual-band omni antenna for connection to a Cisco 3600? For use indoors.
I have found this:
http://www.cisco.com/en/US/docs/wireless/antenna/installation/guide/ant2544v4m-r.html
But it seems a bit overkill for what I need. All I want is a small profile indoor antenna I can connect to the AP.
I require the antenna so that the AP can be mounted vertically with the antenna sticking out the top so as to create the correct coverage pattern
1 ACCEPTED SOLUTION
Hall of Fame Super Gold
http://www.intermec.com/public-files/product-profiles/en/CiscoAntennasAccessories_spec_web.pdf
Hi Kashif,
This document link you've posted is already OUTDATED.   All the antenna's in this PDF are valid up to the AP1250.  The antenna required for the 3600, as what is stated by the OP, is totally different.
Antennas for the newer generation of Cisco APs which are dual-band radios, go here.
Re: Dual-band Omni External Antenna
Go here:  Antenna Product Portfolio for Cisco Aironet 802.11n Access Points
Look at Table 5, 6 & 7.
If "low profile" is what you are looking for, then the ceiling-mounted AIR-ANT2524V4C-R is your best bet.
Silver
The following link provides good guideline which external antenna to select
Hi Kashif,
Silver
you are right n thxs for the update
Thanks everyone
307
