Community Member
Dynamic Interfaces w/Multiple WLC's & SSID's/VLAN's
The setup I'm working on will use 3-WLC's with 6 user SSID's. The deployment guide and config guide state that I should configure a dynamic interface for each VLAN and assign an IP address, then assign each SSID to their respect VLAN.
Does a virtual interface assigned to a corresponding VLAN on different controllers get assigned a different IP address?
WLC-A -->SSID:Faculty1-->VLAN 10-->>IP: 10.0.0.1
WLC-B -->SSID:Faculty1-->VLAN 10-->>IP: 10.0.0.2
WLC-C -->SSID:Faculty1-->VLAN 10-->>IP: 10.0.0.3
1 REPLY
Community Member
Re: Dynamic Interfaces w/Multiple WLC's & SSID's/VLAN's
Your dynamic interfaces look good.
All controllers should have the same virtual IP addresses, typically 1.1.1.1 - this is used more for inter-controller mobility.
197
