E: Radio Error : 38 Queue full discards<000>
this Error is flooding my two 340 root Bridges. Does anyone have any idea what this mean and how to fix this error?
  • Other Wireless - Mobility Subjects
1 REPLY
Silver
Re: E: Radio Error : 38 Queue full discards<000>
This is attributed to ethernet traffic coming in faster than it can get across link due to link being bad.
I strongly suspect that you have bad antenna cables, bad antennas, or misaligned antennas. You need to check the cable, antenna alignment. Also, can you run a carrier busy test? And a signal strength test under Diagnostics? This will check
for
1)interference: which will determine what frequency is best to hardset this on
2) strength and quality of signal.
http://www.cisco.com/warp/public/102/wlan/errors.html#rtx
288
