Community Member
EAP Authentication fails with Windows 2000 clients!!!
Here is the debug log from my 350AP when a Windows 2000 client tries to do EAP-TLS authentication. I've installed the 802.1x hotfix and have installed a user certificate. Thanks
1 day, 02:13:33 (Info): Station [Windows2K#1]000bfd63b771 Associated
RADIUS: Sending EAP-Request/Identity(id=15) packet to client Windows2K#1
EAP: Received EAPOL-Start from client Windows2K#1
RADIUS: Sending EAP-Request/Identity(id=16) packet to client Windows2K#1
EAP: Received EAP-Response/Identity(id=16) packet from client Windows2K#1
EAP: Forwarding packet to RADIUS server
RADIUS: Received packet for client Windows2K#1
RADIUS: Received Challenge Request
RADIUS: Server's state attribute was saved
RADIUS: Received session timeout request of 30 seconds
RADIUS: Sending EAP-Request/EAP-TLS(id=17) packet to client Windows2K#1
EAP: Received EAP-Response/EAP-TLS(id=17) packet from client Windows2K#1
RADIUS: Appending EAP attribute value of length 255
RADIUS: Appending EAP attribute value of length 133
RADIUS: Sending EAP-code=104/type=116(id=111) packet to client Windows2K#1
EAP: Received EAP-Response/EAP-TLS(id=18) packet from client Windows2K#1
RADIUS: Sending EAP-code=111/type=26(id=119) packet to client Windows2K#1
EAP: Received EAP-Response/EAP-TLS(id=19) packet from client Windows2K#1
RADIUS: Appending EAP attribute value of length 136
RADIUS: Sending EAP-code=103/type=114(id=110) packet to client Windows2K#1
RADIUS: Sending EAP-Request/Identity(id=21) packet to client Windows2K#1
EAP: Received EAP-Response/Identity(id=21) packet from client Windows2K#1
RADIUS: Sending EAP-Request/EAP-TLS(id=22) packet to client Windows2K#1
EAP: Received EAP-Response/EAP-TLS(id=22) packet from client Windows2K#1
EAP: Received EAP-Response/EAP-TLS(id=23) packet from client Windows2K#1
EAP: Received EAP-Response/EAP-TLS(id=24) packet from client Windows2K#1
Session-timeout for station 000bfd63b771
1 day, 02:14:34 (Warning): EAP retry limit reached for Station [Windows2K#1]000b
fd63b771
1 day, 02:14:34 (Info): Deauthenticating [Windows2K#1]000bfd63b771, reason "Prev
ious Authentication No Longer Valid"
It would seem that it is trying a couple of times and then failing. Yet, my setup works fine on a WXP machine. Thanks
Re: EAP Authentication fails with Windows 2000 clients!!!
What version ACU NDIS and firmware on the win 2k client ?
Community Member
The ACU is 6.00.23. Thanks
Jason what about NDIS and firmware versions???
184
