EAP-FAST with 2 APS and 1 Repeater
Is possible to configure this WLAN??
I have configured one of the APs as the RADIUS Server and the EAP-FAST on 2 APs.
The tests with one client are correct.
Now I have to put one repeater, because there is no possibilty to connect to the wired LAN and I don´t know how to configure this AP.
Any idea?
1 REPLY
Re: EAP-FAST with 2 APS and 1 Repeater
Yes you can configure..
By just changing the station role as repeater and creating the same ssid as in Root AP with infrastruture-ssid..
sample:
dot11 ssid xxx
authentication open eap eap_methods
authentication network-eap eap-methods
authenticaiton client username password <****>
infrastructure-ssid
int d0
ssid xxx
encryption mode
station-role repeater
no shut
if you required mode help plz do mail me.at sthaliya@cisco.com
Subbu
133
