Community Member
EAP-TLS or PEAP on PDA
I plan to implement IEEE 802.1x running either PEAP or EAP_TLS on HTC smartphone with Windows Mobile 6.0.
The RADIUS servers used is ACS 4.2.
I would like to know if there is anyone successfully implemented the above scenario? Can you provide the guide to deploy it?
Thanks.
Delon
125
