08-26-2010 06:05 AM - edited 07-03-2021 07:07 PM
We have a WCS running Version 6.0.170.0 and 10 WLC connected to it. We have around a 100 sites and we want an email notification when we lose Access Points just at specific sites. Can anyone help me with this?
Solved! Go to Solution.
08-26-2010 08:55 AM
Hi Andrew,
there is no way we can do that its for all the aps
Surendra
08-26-2010 06:41 AM
WCS >> home >> Monotor >> Alarms >> Left top in the drop down >> Select EMAIL NOTIFICATION >> GO >> Check Access points.
You will be done
Surendra
08-26-2010 08:26 AM
Thanks surendra but I only want to monitor 10
of the 750 access points we have. is there a way of doing this?
08-26-2010 08:55 AM
Hi Andrew,
Surendra
