Users might experience few discrepancies in Search results. We are working on this on our side. We apologize for the inconvenience it may have caused.
Emergency version N/A 6.0.188
I have upgraded to the new release and the EM image version is N/A have tryed to upgrade the ER version to 5.2.157-ER. But the same status N/A exists after.
Re: Emergency version N/A 6.0.188
I believe you are hitting the instance of the bug CSCtd17116 which is seen after the WLC is upgraded from 6.0.182.0 to 6.0.188.0 code version. The Emergency Image version is installed however the actual operating system is unable to show the proper version.
II just upgraded my 4402 to the latest 6.0.188 and i completed suscesfully but I cannot ping the Controller.  I tehn check the cdp neighbor and notice the new version on the controller but the controller lost the ip address. ip address shows 0.0.0.0.
What enxt ?
469
