Enabling Antenna Gain On 1242 AP's
If we are using 1242 access points with external antennas there is an option to configure the antenna gain in the WLC.
If we are using 2 * 5135 Antennas how we will configure the antenna gain. Antenna Gain is a factor of *0.5 dBi.
1 REPLY
Gold
Re: Enabling Antenna Gain On 1242 AP's
Since that antenna has a gain of 3.5 you would configure 7.  You just enter twice what the antennas gain is.
1828
