Error when migrating AP 2600 from Autonomous to Lightweight
david_mayor
I am trying to migrating AP 2600 series that came with autonomous image 15.2 to lightweight using the Cisco Prime Infrastructure built-in migration template.
The AP successfully downloads the image from an external TFTP server but fails at updating the environment variables.
The logs show that the AP should download a text file from Cisco Prime but fails to do so:
START: Detailed logging started at -> 01.22.2014_14.01.52
INFO: TELNET to device 10.32.148.225 done.
INFO: Privilege level is equal to 15.
INFO: Setting vty line completed.
INFO: Dumped Environmental variables.
INFO: AP is supported for Upgrade process
INFO: IOS version is greater than or equal to 12.3(7)JA.
INFO: AP has MIC installed already.
INFO: Station role is root.
INFO: DNS and Domain name configured.
INFO: Mac address of device is 88:5a:92:17:2b:09
INFO: Completed Dot11Radio0 shutting.
INFO: Device set up done and time configured on device.
INFO: Run-config dumped.
INFO: AP is DHCP configured.
INFO: Hostname gbknwa2225sr
INFO: Starts loading recovery image, takes time based on link speed.
INFO: Image Loading done.
INFO: Copying updated Env. variable file to WCS local tftp server 10.70.165.165
INFO: Copying the Env. variable file from tftp server to device.
Copying the Env vars to device failed.
ERROR: Device Response ::
copy tftp://10.70.165.165/Env_vars_10.32.148.225_01.22.2014_14.07.55.txt flash:/env_vars
Destination filename [env_vars]?
%Warning:There is a file already existing with this name
Do you want to over write? [confirm]
Accessing tftp://10.70.165.165/Env_vars_10.32.148.225_01.22.2014_14.07.55.txt...
%Error opening tftp://10.70.165.165/Env_vars_10.32.148.225_01.22.2014_14.07.55.txt (Timed out)
gbknwa2225sr#
gbknwa2225sr#_tune_
gbknwa2225sr#
INFO: Un-shut radio 1 done.
END: Migration Process Failure: Copying Env_Vars to device failed.
What can I do to solve that ?
Many thanks for your help,
David
Hi David,
I think 2600 AP not supported on Prime Infra for autonomous to Ligtweight migration.
PI 1.2, 1.3, 1.4 , 2.0
Only these APs are supported: Autonomous to Lightweight Migration Support
  • Cisco Aironet 1130 Access Point
  • Cisco Aironet 1200 Access Point
  • Cisco Aironet 1240 Access Point
  • Cisco Aironet 1310 Bridge
  • Cisco Aironet 1410 Bridge
Check this link:
http://www.cisco.com/en/US/docs/wireless/prime_infrastructure/1.4/configuration/guide/ctrlcfg.html
Hope it helps.
Dont forget to rate helpful posts
Sandeep Choudhary
Better to do with console access.
use mentioned above method and try again.
Hi, with the archive command, I could make it work.
But do you know why it did not work from Prime ?
Hi David,
Check this link:
Hope it helps.
