03-10-2010 11:41 AM - edited 07-03-2021 06:36 PM
I have a 1240AP and I am getting the message that the Ethernet port failed to initialized is this a hardware failure or is there a setting that needs to be changed?.
Reload Command.
Xmodem file system is available.
flashfs[0]: 147 files, 7 directories
flashfs[0]: 0 orphaned files, 0 orphaned directories
flashfs[0]: Total bytes: 15998976
flashfs[0]: Bytes used: 5479936
flashfs[0]: Bytes available: 10519040
flashfs[0]: flashfs fsck took 27 seconds.
Base ethernet MAC Address: 00:23:5e:03:fa:ba
Initializing ethernet port 0...
Reset ethernet port 0...
Reset done!
link auto-negotiating....
auto-negotiation takes 10000 milli-seconds to complete
ERROR: timeout waiting for auto-negotiation to complete
ERROR: fail to bring ethernet link up
The system has been encountered an error initializing
ethernet port. You may need to check hardware
The system is ignoring the error and continuing boot.
If you interrupt the system boot process, the following
commands will reinitialize ethernet, tftp, and finish
loading the operating system software:
ether_init
tftp_init
boot
03-10-2010 01:04 PM
What is the switch model is connected to the AP? Are you using PoE or power injector/power brick?
03-10-2010 01:08 PM
It give me the same responce if it is connected with power injector or connected to any of our Switch which are 3Com right now it is connected to a cisco SWR2008
03-10-2010 01:33 PM
So when you do the command "sh ip interface brief" the FasthEthernet0 is showing up/up or up/down or down/down?
03-10-2010 02:01 PM
this what comes up
BVI1 unassigned YES DHCP down down
Dot11Radio0 unassigned YES unset administratively down down
Dot11Radio1 unassigned YES unset administratively down down
FastEthernet0 unassigned YES other up down
03-11-2010 01:15 PM
I've never seen this issue before. Could it be that the switches you are using have their port and duplex setting hard-coded?
03-11-2010 01:17 PM
nope double check that one and tried diffrent switches
03-11-2010 02:15 PM
I do pray you have a valid Service Contract because this is the next thing I can think of. RMA.
03-11-2010 02:22 PM
that is what I was thinking thank you for you time
03-11-2010 02:25 PM
Thank you for your patience.
03-12-2010 05:24 AM
Easiest thing is to connect your laptop to the ethernet port of the AP and see if you can initialize the port or else like Leo said.... its RMA time:)
11-23-2010 12:30 AM
I found solution specified the configuration in interface, basicly is
#enable
#configure terminal
Entramos en la interfaz
#interface FastEthernet0#speed 100
#full-duplex
You can see more here
http://www.syswoody.com/cisco/antena-cisco-1240-error-fail-to-bring-ethernet-link-up
Regards.
