External Omni-Directional Antennas
Hello guys,
Does the 3502e and 3602e have dual-band omni-directional external antennas that can be mounted on the wall?
I have been searching the net, but all I could find was the wall mountable single band antenna and it was only for 3502e.
Hall of Fame Super Silver
Re: External Omni-Directional Antennas
Here are antennas for the 3602e. These are dual band with four leads. I have used then on other AP's as well. For the 3502e's the antennas are single band. You can use the 3602e antennas but you either would need two antennas or only use two antenna ports in each band.
http://www.cisco.com/en/US/prod/collateral/wireless/ps7183/ps469/at_a_glance_c45-513837.pdf
-Scott
Here are antennas that are 6 lead
http://www.terra-wave.com/pdf/Cisco%20Compatible%20Products_6Lead_External.pdf
-Scott
350
