02-05-2004 07:44 AM - edited 07-04-2021 09:20 AM
All clients are unable to do LEAP authentication after a ACS 3.0 upgrade.
On the ACS error message is Radius Extension DLL Rejected user
On the AP error messgae is Failed EAP-Authentication
Using External Database to WIN2K Domain.
02-11-2004 07:09 AM
Seems like you hit upon a bug, CSCdy81816 - When using AD and ACS on the different machine, LEAP authentication fails. The given work around is to run both the services from the same server.
02-12-2004 01:41 PM
I would upgrade to the latest ACS which is 3.2. I was having EAP problems until I upgraded.
03-14-2004 12:24 AM
or take a look at this link and make sure you have met all the requirements. This is for running ACS 3.0 on a member server in a domain.
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_soft/csacsapp/raig/rawi.htm#642349
This is for a remote agent confgiration, but look at the "Windows Authentication from a member server" section
