Highlighted
Community Member
Failed to start driver for port "awc0"(error=0x00000000)
Hi there ,
wonder does anyone come across above error message recorded in your AP logs ( as below )
b)Warning Failed to Send Packet on port "awc0" (error=0xffffffff)
a) FATAL Failed to start driver for port "awc0" (errno=0x00000000)
Clients have to reassociate with these AP after deassociated.shall send these AP for RMA ? pls share ..thks
1 REPLY
Community Member
Re: Failed to start driver for port "awc0"(error=0x00000000)
Check the config and make sure that your AP ports aren't configured with auxiliary vlans. Unless you plan on plugging in an IP phone to the same port as the AP you really only need to have the port configured for a single vlan. Hope that works for you.
Cheers!
Cisco_Kid
169
