fastethernet hardware status down
I have a 1400 Bridge connected to 1300 AP using 2940 switch. Things were working fine. When I reveiwed the IOS the fastethernet hardware status was DOWN. What some things to resolve this and bring back UP?
Green
Re: fastethernet hardware status down
WHICH Fastethernet port is down (AP, Switch, or Bridge)?
Check the cabling, check the power injector / brick, try doing a shut / no shut on the affected interface, try another port of the switch (for both bridge and AP) ...
Some details would help a lot
Let us know
Scott
I checked the cabling and switched the power injector. I also shut down and rebooted as well another switch.
The fastethernet port is down on the Bridge
394
