fix an AP to a controller
Network environment:
2 AIR-WLC2106-K9 - Software Version 7.0.235.0
2 AIR-WLC2112-K9 - Software Version 7.0.235.0
10 AIR-LAP1252AG-T-K9 - Software Version 7.0.235.0
10 AIR-LAP1131AG-A-K9 - Software Version 7.0.235.0
Running RRM algorithm.
Is it possible to fix an AP to a controller?
2 ACCEPTED SOLUTIONS
Hall of Fame Super Gold
Yes you can.  Once the AP has
Yes you can.
Once the AP has joined the controllers you can specify the primary, secondary and tertiary controllers.  You can do this via CLI or GUI.
Hall of Fame Super Silver
AP's join another WLC because
AP's join another WLC because they lost connectivity with the one it was assigned to. RRM has nothing to do with this. Your better off setting the primary, secondary and tertiary WLC on the AP if your WLC's are on the same mobility group. Also make sure AP fallback is enabled if you want the AP to return to it's primary WLC.
Scott
-Scott
Yes you can.
Yes I have done this before,
Yes I have done this before, but as time goes by APs change from one controller to another.
Is this  caused by RRM AP's power changes ?
Scott
-Scott
you may do that by adding a
you may do that by adding a dhcp option 43  to the dhcp scope for APs. This dhcp option 43 is a hex value of the WLC IP Address where you want to link the AP to.
search google for ip address to hex value convertor and guidelines on how to write that hex value in the dhcp scope.
59
